Danny B
发表于 2021-8-31 22:40:32 | 显示全部楼层 |阅读模式
I have a Lincoln weldan 150. It has no voltage output at 110 plug or welder lugs.Stator shows no voltage output on either wire. Can I supply voltage to wires coming from stator to brushes as a test to see if generator will work? If so how much voltage?Can voltage be applied to welder transformer  with generator not running and disconnected  to weld with? If so how much voltage? AC or DC voltage?150 amp welder
Reply:I dunno..wish I could help.Well, maybe I can help...If you repost the question, and in the title line offer a condensed version of your question, you will get lots more views and possible answers.Maybe say, 'Weldon 150, no output, no arc problem', or something to that effect.Not trying to be forum gatekeeper, I just want to see you get help.
GMT+8, 2025-12-30 10:01 , Processed in 0.095870 second(s), 18 queries .
