door security
发表于 2021-8-31 22:40:32 | 显示全部楼层 |阅读模式
hi thereI have built a few steel doors out of 40mm box iron. these have all been hinged doors  and in places where high security isn't required. I have to build a sliding doorI don't think the sliding part will be a problem. what I am looking for are ways to lock and secure the door. this is a door for a workshop so security will be high. thanks  alan
Reply:Probably waaaaaaaaaaay overkill but not long ago I worked putting together a project for a jail in Mexico (for women, mind you). I had been involved in access controll and security before, but never at this level. I came across a few brands but we settled on Airteq for our specifications. You may have a look at their products and you will probably be able to steal some ideas. You could also just buy the lock and incorporate it into your sliding door design.Mikel
Reply:Cane Bolts sunk deep into the floor.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:King Architectural has a variety of solutions.
Reply:Originally Posted by nadogailCane Bolts sunk deep into the floor.
Reply:You just need to make a steel door jam so the door can slide into it and then locked by a dead bolt.http://www.nxstagesecurity.com/image...ty_door_14.jpgEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Are you talking bypass doors or rollaway  Considered cantilever?
Reply:the door will role all the way to the right to leave the full opening free. thinking more about how to phrase this. I think I am really asking more about how to protect a pad lock or creating a system where the locking mechanism is really secure
Reply:I have used these. I just mortise them into a 2" tube (usually 2x4).http://www.kingmetals.com/Catalog/It...ilId=538&NSM=Y
GMT+8, 2025-12-30 09:54 , Processed in 0.100063 second(s), 18 queries .
