How much would you pay for these tables?
发表于 2021-8-31 22:40:31 | 显示全部楼层 |阅读模式
How much would you pay for one of these tables? The ad says 1/2" top, 88" wide, 33" across
Reply:It would depend on how badly I needed them and what other alternatives I had at the time.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:couple hundred bucks considering the current price of scrap.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Scrap price, plus maybe $20.  They are a very unusual shape and were probably built for a specific purpose.  Unless you have a very similar special purpose, there is a lot of wasted space there.  There will be even more wasted space in your shop.  The strength of the legs isn't up to the strength of the top, and the crossbracing needs reworked so you can set in the center of the table.
Reply:I wouln't even buy them,. why save a few dollars just to have to work on some crazzzzy shaped table all the time, pound foolish, penny wise IMHO.
Reply:I might go $50 just because I have a couple corners they might work into and I know it would cost more than that to make them. Not my favorite design though...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Around here they would go for $100 or so each.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Price out some flat 1/2" plate large enough to build a table. Those tables may not be the most desirable shape but they're still 1/2" plate and 1000 times better than any wood bench for working with steel. For instance, if you were TIG welding using a foot pedal, they would make an excellent table. Maybe I'm crazy but if I needed a steel table(s) I'd probably pay a couple hundred bucks for them.
Reply:If you can get them for cheap, and you have a plasma cutter, buy them and rework them to the way you want.AHP AlphaTig 200x 3rd gen.Lincoln Power Mig 210MP
Reply:I kinda like them. Look like great assembly work tables or as previously mentioned, TIG welding tables. Sit a chair or stool in that inner radius and you have more area within your reach than the conventional square table. If you got the space, maybe take one of them. I would probably buy one for $100!John 3:16(2) Miller Pheonix 456(2) Millermertic 252Dynasty 210DXHobart 210MVPDoringer D350 SA Cold SawScotchman 350LT Cold SawWebb 10x50 MillWebb 15x40 LatheGeka Bendicrop Ironworker
Reply:Those were the shape of the reading desks we had when I was in first grade. Teacher on the inside, 4 or 5 of us on the outside. Great for such applications, but the crossbars need removed for that.  Might be great for kids art table applications but really hard to see any other use, the weight and 'danger' of metal makes me think schools and preschools/day care would say no thanks.  As others mentioned, may be perfect for tig, or even assembly like mig or stick applications.MillerMatic 252Miller Xtreme 625Miller Digital Elite
Reply:I kinda like them. Yes they would take more room, but you could reach more of the work area easier. If I had the room I would take one.Yeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:Just thought of something! Green felt, and let's deal up some Texas Hold'em! Now I want one!MillerMatic 252Miller Xtreme 625Miller Digital Elite
GMT+8, 2025-12-30 09:54 , Processed in 0.074316 second(s), 18 queries .
