need help with used tool list
发表于 2021-8-31 22:40:29 | 显示全部楼层 |阅读模式
Milwaukee Horizontal Mill 12’ X 47” - Kearny and Trecker Milwaukee Horizontal Mill 13’ X 64” - Le Blond 17” X 48” Engine Lathe - Chicago Blower and Forge Lathe 12” X42” - 10” Double Wheel pedestal grinder - 6” Double Wheel Pedestal grinder - Whitney Jensen Sheet Metal Shear 6’ - National sheet metal shear 5’ - Peer Water Cooled Spot Welder 64” - Royer’s Ford Drill Press 21” - Floor Model Drill Press (Boyce) 16” - Liberty Sheet Metal Circle Cutter 72” - (2) Shepard Thompson Rivet Machines 8” - Ferracute Mach-Punch Press #51 - Toledo Punch Press - Fairbank Morse Drill Press 12” - Sae 200 Lincoln Welding Machine - Rockwell 14” Band Saw - 14” Band saw what looks intersting to you and whats it worth?.  there is a shop closing down may go look at some of this stuff.Lincon Ranger 250 GXT, Lincoln 135plus mig, Lincoln 225 AC/DC cracker box, Hypertherm 45 awaiting arrival,  really want a plasmacam table!
Reply:An approximate location of the "shop closing down" would help in determining interest on my part.Just sayin'.Rex
GMT+8, 2025-12-30 09:54 , Processed in 0.099587 second(s), 18 queries .
