Band Saw For Sale
发表于 2021-8-31 22:40:27 | 显示全部楼层 |阅读模式
I have a large band saw for sale. It has no manufacturers tag on it to identify it, but it appears to be pretty old. Heavy cast iron construction, 110 VAC single PH motor appears much newer than the saw. It has a 3/4" blade that looked fairly dull, but when I tested it on a piece of 2" sq. solid, it cut it fast & square. Runs smooth & quiet. Will take $750.00. Local pick up in Melbourne FL 32904Terry Mathews321 427 [email protected] Attached Images
Reply:It's a Wellsaw.   $750 seems like a good deal.
Reply:Thanks for the ID. Yup, I think its a good deal, these old things seem to never wear out. they just need a little fixing up every 20 or 30 years.
Reply:I will probably bet thats an early 50's version.  They designed it in 1937.  Still build the same one today but with safety features.   I got a smaller version and love it.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
GMT+8, 2025-12-30 09:54 , Processed in 0.227162 second(s), 19 queries .
