1/4" Penetration Test- HH140 vs Oxy Acetylene
发表于 2021-8-31 22:40:23 | 显示全部楼层 |阅读模式
Here's an un-scientific test of penetration between oxy acetone and a 115v hobart handler 140 running 5v/50wire speed with .30 wire 75/25 mix @ 20cfm.Not really trying to make a point here rather just testing my new HH140 capabilities vs my old torch.It's all 1/4" hot rolled steel butt joints.From left to right:Oxy Acetylene beveled at jointHH140 non-beveled non-preheatHH140 beveled and preheatedThe 140 had trouble with the 1/4" stuff until I beveled and pre-heated the joint.Sent from my iPhone using Tapatalk
Reply:Welding 1/4" with O/A takes a fairly good sized tip.  One too big for those little plumbers tanks."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by OldendumWelding 1/4" with O/A takes a fairly good sized tip.  One too big for those little plumbers tanks.
Reply:Looks like you only beveled ~25% of total steel thickness from each side on the OA test, is that correct?
Reply:Originally Posted by G-sonLooks like you only beveled ~25% of total steel thickness from each side on the OA test, is that correct?
Reply:I use a #5 on a V100 for 1/4" and fill with 3/32 RG45. Beveled down half way.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by BurpeeI use a #5 on a V100 for 1/4" and fill with 3/32 RG45. Beveled down half way.
GMT+8, 2025-12-30 10:42 , Processed in 0.072552 second(s), 18 queries .
