50 amps = 50 amps?
发表于 2021-8-31 22:40:18 | 显示全部楼层 |阅读模式
Is it the same regardless of whether I'm using a 110 of 220?Miller Diversion 165 TIGMillermatic 211/141 with Auto-SetHobart Stickmate LX235 AC/DC StickNorthern Tool 135 MIG & Dry Cut SawKlutch ST80i/ST200i Stick/TigGrizzly G9742 BandsawMilwaukee Circular Steel Saw/Portaband/SWAG Offroad Table
Reply:On the input, 50 Amps at 220 Volts is twice the power of 50 Amps at 110 Volts."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by SpEd50 amps = 50 amps?Is it the same regardless of whether I'm using a 110 of 220?
Reply:Originally Posted by MikeGyver... 50 amps at 10000000volts is 50 amps...
Reply:Originally Posted by SpEdIs it the same regardless of whether I'm using a 110 of 220?
Reply:I think what a lot of people get confused about in regards to say 220V @ 50 amps, is that there are two "hot" wires on a 220 circuit.  Each "hot" wire is 50 amps.  This does not equal 100 amps.  These are two different 50 amp circuits.  On a 110V @ 50 amp circuit, there is only one "hot" wire at 50 amps.
Reply:Power (Watts or Volt Amps) is not measured in amps.  Current flow is measured in amps.Are you asking about the input power to your welder or the setting for output to the work?50 Amps at 220 volts is twice the power as 50 Amps at 110 volts.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Originally Posted by gwbutch...These are two different 50 amp circuits.  On a 110V @ 50 amp circuit, there is only one "hot" wire at 50 amps.
Reply:Originally Posted by OldendumNo, on 120V the neutral is "hot" when when using either of the other "hot" legs as a reference.  Since neutral and ground are tied, neutral appearsto have little or no voltage if ground is used as a measuring reference. I know, picky ...
Reply:Originally Posted by teh603Are we talking input or output? I've seen a lot of discussion on input, but nobody's touched output.
Reply:Originally Posted by MinnesotaDaveI have a dual voltage stick/tig welder.  When run on 120v or 220v, when I turn the dial to 50 amps, that's what is coming out the tig torch.Is that your question?
Reply:Originally Posted by SpEdYes, in reference to stick welding. If I was smarter I likely could have phrased that question better. Let me try again. I'm using a 220 and a 110 welder both set at 50 amps. Using the same rod will they weld the same thickness of steel, or will the 220 be able to weld a thicker piece of steel?On one hand I'm a real rank amateur at this so I apologize for all the confusion.   On the other hand I am having an absolute blast learning how to weld and really appreciate everyone's help here.
Reply:In that case (output).  50 amps is 50 amps.  Or at least it should be.  A 220 v welder may have a bit better quality arc, but that really depends on the machine.My name's not Jim....
Reply:Originally Posted by BoostinjdmIn that case (output).  50 amps is 50 amps.  Or at least it should be.  A 220 v welder may have a bit better quality arc, but that really depends on the machine.
Reply:On the output, 50 Amps is 50 Amps.  HOWEVER, not all welders have the same kiloWatt output capability.  Big old welders could manage 40 arc Volts to try and get to rated current output in a bind. Lightweight welders cannot. There is no substitute for raw power. It takes power to get it going and energy to get it all melted together."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:,.,.,Last edited by MikeGyver; 04-01-2015 at 03:57 PM.Welding/Fab Pics: www.UtahWeld.com
GMT+8, 2025-12-30 10:53 , Processed in 0.305122 second(s), 18 queries .
