Copper lugs on aluminium post
发表于 2021-8-31 22:40:17 | 显示全部楼层 |阅读模式
I recently bought a Lincoln weld an power and noticed it had aluminum post.  I am to cheap to buy lugs so i make them out of scrap 1/2 inch copper pipe thats have laying around.  The galvanic scale says that's a no no.  Has anyone had bad corrosion on the welder connections because of this or am i worrying bout nothing?  Thanks, Matt
Reply:Originally Posted by mattsmithI recently bought a Lincoln weld an power and noticed it had aluminum post.
Reply:Originally Posted by mattsmithI recently bought a Lincoln weld an power and noticed it had aluminum post.  I am to cheap to buy lugs so i make them out of scrap 1/2 inch copper pipe thats have laying around.  The galvanic scale says that's a no no.  Has anyone had bad corrosion on the welder connections because of this or am i worrying bout nothing?  Thanks, Matt
Reply:Thanks Rodger
Reply:As long as your connections are dry the rate of corrosion is slow.  I worked for a short time at a lead zinc smelter and the welding machines had steel nuts on the copper studs... Frozen solid together.  Even temperature had an effect.  Below 40 degrees F. corrosion rates fall off.  I have seen the results of stainless steel against aluminum on a sailboat returned after a season in Mexico.  I was amazed to see corrosion that would have taken over five years up here in Canada.
Reply:You mean like this? $2.20 @ the HomoDepo.
Reply:Mike your mom is hotttt.  Pipeliner no not like that.  I literally took a piece 1/2 inch plumbing pipe crimped/smashed on the ends of the welding leads, drilled a hole, and soldered the wire in the pipe.  I am cheap i wont spend the money the gas or the time it takes to go to the store if i don't have to.   Lotech I to have seen corrosion in boats from stainless rivets in aluminum hulls.  I will be looking up the paste that Rodger is talking about
Reply:twist lock with copper plate soldered in the slit in the middle of the connector and a hole drilled for the post(bought a used torch and to cheap to buy female twistlock) pipe lugs
Reply:I think you will find the weld stud in the picture is plated yellow brass.
GMT+8, 2025-12-30 10:42 , Processed in 0.094294 second(s), 18 queries .
