any use one of these?
发表于 2021-8-31 22:40:14 | 显示全部楼层 |阅读模式
tanaka torch guide. Attached Images
Reply:I haven't used that brand, but I have used and love a track torch.  You can achieve some beautiful cuts with one.
Reply:http://tanaka-sales.com/here is a link to the sales for it.
Reply:Very cool. I want to get one to make nice cutting edges."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:nope, but i want one though
Reply:We have an awesome track torch at school..
Reply:They call it a track burner.http://images.google.com/images?hl=e...h+Images&gbv=2Last edited by tanglediver; 03-19-2010 at 01:47 AM.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:This is a little different than a typical track burner because it doesn't have a drive motor and appears to be all mechanical. I'm guessing that the gear box houses some sort of a speed governor. Maybe Offdiggin can tell us how the speed control works?The gear rack looks like it would be a pain; one stray piece of slag or dirt and torch travel would stall.I'm guessing it's not a portable, because the track would seem difficult to anchor. I guess I don't see any advantage over the type of track burner which rides directly on the work, or on common readily available angle.Good LuckLast edited by denrep; 03-19-2010 at 06:54 AM.
Reply:it is portable it has magnets on it. the set up is easy line up your cut and go.it has a clutch that is either on or off.
Reply:I used one for more than 20 years in a production shop. It's AMAZING how well it held up in such a harsh environment. It was still in operation after I was let go. It has some sort of ratcheting (escapement?) mechanism that causes the carriage to travel at a smooth even speed. If you want to move faster you simply pull harder on the torch. The finished cuts looked like motorized track torch cuts. Unfortunately, these things are REALLY PRICEY now. For occasional use, it's hard to justify the cost. If you plan to use it on a daily production basis, it might be worth considering.
GMT+8, 2025-12-30 10:43 , Processed in 0.121246 second(s), 18 queries .
