getting better with 7018
发表于 2021-8-31 22:40:08 | 显示全部楼层 |阅读模式
i've been welding with 7018 3/32 rods on 1/8 steel  at 90 amps and sometimes 80 ampswith a good results no burn through at all i was wondering   what is the thickest steel ucan weld with 7018 3/32.
Reply:I wouldn't go over 1/4-inch thick, before switching to 1/8-inch rod. So now you're ready for pipe?Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Thick as you want. When welding larger joints 3/32" just doesn't put down enough weld to be productive(slow).Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by SquirmyPugThick as you want. When welding larger joints 3/32" just doesn't put down enough weld to be productive(slow).
Reply:7018, my favorite rod. I run my 3/32 at 80-100 depending on position and weld joint type. The material thickness is not a factor. For example, you just have to run additional passes if you want fillet welds larger than 1/4".ChrisAuction Addict
Reply:My magic number for 3/32 7018 is 86 for most pipe positions. Depends on the machine though.I've used 3/32 on xxl pipe just fine. Takes a crap load of passes though.
Reply:Isn't metal thickness a factor in getting good penetration?   If you were welding 1" or 2" thick steel, would 3/32" rod at 100 amps provide enough heat for good penetration?
Reply:Originally Posted by k45If you were welding 1" or 2" thick steel, would 3/32" rod at 100 amps provide enough heat for good penetration?
Reply:Originally Posted by k45Isn't metal thickness a factor in getting good penetration?   If you were welding 1" or 2" thick steel, would 3/32" rod at 100 amps provide enough heat for good penetration?
Reply:Originally Posted by CEPNot for me, I would want 5/32 or 3/16-inch 7018.
Reply:Originally Posted by Stick-manHeck, 1" to 2" and I would be playing with all of that 1/4" lo-hy I have!!!
Reply:Originally Posted by jamesyarbroughHell every welder certified in unlimited thickness plate used 1/8 rods on at least 1" plate and it held threw a bend test.
Reply:3/32 on a 1" standard V with the backer D1.1 test..?? ...seriouslyBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by killdozerd113/32 on a 1" standard V with the backer D1.1 test..?? ...seriously
Reply:That's the prob with some Testers, they make welders weld the way they do and not as a WPS or D1.1 allows. I never tell a welder what size rod to use. It's his test and as long as he is in the peramiters and doesn't violate essential virables GO FOR IT
Reply:Originally Posted by CEP. Who calls for a 1 7/8-inch fillet weld? Why not just round it off to 2-inches?
Reply:I only hire W.E's with welding backgrounds, they better be able to pass same test, your right tho
Reply:I worked in a RR car building facility, and the area I was assigned to, I used 1/4" 7018 all day long. I also welded the splice joints, uphill, with the same electrodes and the same amps as it was too far to the machine to change the heat and get different electrodes.
GMT+8, 2025-12-30 11:59 , Processed in 0.117090 second(s), 18 queries .
