trouble with my mig wire feeding
发表于 2021-8-31 22:40:07 | 显示全部楼层 |阅读模式
im not sure if this where i should post thiswhen i am welding the wire stops feeding it get stuck and i have to pull it out with pliers then it goes and or some times it get unstuck by it self but when i just hold the button in and it not welding the wire goes fine but when welding it like it serges the welder is about 5-6 years old but we dont use it that much maybe 2-3 times a year so im not sure if the welder has had it or what
Reply:Try the simple stuff first. Replace the contact tip,check that the drive roll pressure is set correctly(more is not better),is the spool spindle tension correct. If those check out ok pull the liner from the gun to see if it is kinked or dirty,pretty ceap and easy to replace.
Reply:I have had trouble like this that turned out to be rusty wire. This can happen if it's humid in the shop (or outside), and is only barely visible.XMT 350 MPA Dynasty 280DXSuitcase 8RC / OptimaSpoolmatic 30AThermco Ar / C02 mixerAssorted O/A gear
Reply:Check your feed roll alignment, also crap likes to build up on the inlet guide.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:I've had a similar problem, caused from the wire spool "stuttering" while turning.  The paper label on the interior end of the spool was uneven, and rubbing unevenly against the housing.  I solved it by tearing the label off and placing a large, thin plastic washer between the housing and the spool.  Since I wind my own small spools, I don't have the label issue anymore.Last edited by Weldordie; 11-11-2013 at 02:01 AM.
GMT+8, 2025-12-30 11:50 , Processed in 0.075640 second(s), 18 queries .
