Argon regulator...Help!!!
发表于 2021-8-31 22:40:04 | 显示全部楼层 |阅读模式
Hi,it's my first post,need your help,tomorrow I will receive my first delivery of argon at home(E size bottle) and don't know if my regulator is going to be compatible with the cylinder's valve.My welder is a cheap chinese ac/dc 200 amp. tig welder (Please don't laugh) and it came with the regulator with connection on the botton ,my question being is it possible to swap the inlet with the safety valve ?They look the same thread.Asking because most cylinders I've seen have the side facing valve.Please help.Thanks,Alfred. Attached Images
Reply:Why not just rotate the actual flowmeter (tube) 90 deg? If it won't turn anymore, remove it, put some Teflon tape around the threads and reposition it.....Mike
Reply:Hi,Mike thanks for the quick answer ,what you say crossed my mind but all threads are hard as a rock and don't want togo feral and break the regulator.Is it possible that they could have any sealant/adhesive filling the threads?
Reply:Yep, very possible, I've even seen some old regulators that are soldered. I don't know if the safety valve is for the HP or LP side, I assume HP (but you know what assume means),  hopefully someone with more knowledge will pop in ...Mike
Reply:Well that ain't gonna work.Contact the seller and bitch. Or call HTP/usaweld and buy a proper one.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Looks like they gave you an Argoff regulator. Lay the Argon bottle on its side."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Lay the Argon bottle on its side.
Reply:Originally Posted by OldendumLooks like they gave you an Argoff regulator. Lay the Argon bottle on its side.
Reply:Originally Posted by shovelonWell that ain't gonna work.Contact the seller and bitch. Or call HTP/usaweld and buy a proper one.
Reply:At the end I followed what mike suggested and released the flowmeter ,rolled it with teflon tape and tighten it until was in the right angle...looks funny but works.Thanks,for your help.
Reply:Swap that safety and the cga inlet fittingExperience is something you get right after you need it
Reply:Chinaman having a bad case of the Mondays..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
GMT+8, 2025-12-30 11:50 , Processed in 0.119758 second(s), 18 queries .
