bumber mounted water cannon build
发表于 2021-8-31 22:39:57 | 显示全部楼层 |阅读模式
Ok guys i thought id get some of your ideas. Im building a tactical type 2 water tender. I can buy a water cannon for around 6 thousend. But the hell with that. I wanna use the semi's air compressor to fill a tank then push air threw a 1inch line to a nozzel. Im not 100% if that will work? What do you guys think? Ill have pics of what Ive got done so far in the morning.
Reply:with the trucks air supply you would be better off standing on the bumper and tanking a strong whiz.   You need a true water pump to be even remotely effectiveVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Yep, water pump. PTO driven. For fire or zombies?Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
GMT+8, 2025-12-30 11:50 , Processed in 0.069081 second(s), 18 queries .
