My dogs are barking
发表于 2021-8-31 22:39:56 | 显示全部楼层 |阅读模式
Aluminum dog box 42"w x 42"d x 24"h  Used drop from a boat project and one perty piece of diamond plate.  Attached Images
Reply:That Kennel rocks man. I mean it really is nice. I would glue some homosote insulation board or some type of insulation under the top to help with the heat transfer. Might make it cooler for the dogs. Nice job........Fireman BillHH 210 MVPMM 211 Spoolmate 100Lotas LTP5000D PlasmaOxy/Accet (Victor)Wards AC/DC buzz box30 ton old hyd pressA few brand name toolsA bunch of cheap toolsA wife to worry me and4 dogs to supervise me
Reply:Very nice layout and construction.American by birth Southern by the Grace of God
Reply:Thanks, I'm still learning the settings on the tig machine and the more I learn the more fun it gets.
Reply:Real nice. I don't think my Panda would fit.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:looks goodOn this view, you cut and fit and welded in all those small bits to form the horizontal bar, why not just overlap a long piece so you don't have to spend all that time and work fitting those little bits.
Reply:Originally Posted by 12345678910looks goodOn this view, you cut and fit and welded in all those small bits to form the horizontal bar, why not just overlap a long piece so you don't have to spend all that time and work fitting those little bits.
Reply:Originally Posted by BurpeeReal nice. I don't think my Panda would fit.
Reply:Last edited by g-man; 01-16-2014 at 07:19 PM.Reason: oops
Reply:Originally Posted by BistineauI think it may have to do with using drops from a boat project, and trying to maximize the use of materials, plus he wanted more practice time with the new TIGG man, have you made any provisions to keep it from sliding/bouncing around in the back of the truck?
GMT+8, 2025-12-30 11:52 , Processed in 0.132819 second(s), 18 queries .
