Alfred's Wash(er) Service - Washer type shims and spacers plasma cut while-U-wait
发表于 2021-8-31 22:39:46 | 显示全部楼层 |阅读模式
Alfred's Washer Service - Spacer type  shim washers custom plasma cut  while you wait.Attachment 496731 - Forget those flimsy, thin, stacked-up shims that collect dirt and can fold, twist out, and squeeze apart in no time.2- Accurately gauge your exact needed spacer thickness.3- Measure the gauge and record the needed spacer thickness.Bring a sample for dimensions, and choose from a variety of Alfred's  in-stock materials.Or BYO specific alloy.Remember, there is only one setup fee per run, so now's the time to cut your spares.Attachment 49674Blanks are pierced so they can be bolted on the Washer-Machine's rotating spindle.The work (ground) clamp bonds the spindle to table to protect the drill motor from any stray plasma cutting currents.Attachment 49675The shape of the blank, and its center hole's size and location are not overly critical, as these areas will be scrap. Once the cutting guides are adjusted and clamped in position, duplicate identical-sized  washers are quick and easy to cut, without making further adjustments.Attachment 49676Unlike thin stacked shims, Alfred produces one thick precision fit spacer, which won't be "spun-out" or easily chewed away by movement.Attachment 49677Please take a tour:Last edited by denrep; 10-19-2010 at 11:44 PM.
Reply:Now thats cool...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:OMG..................IS THAT A PERFECTLY GOOD BROWNE AND SHARP SLOTTING SAW THAT JUST BIT THE DUST??????It went to a better place, where it could begin a new life. Very cool in a Hindu sorta way "Any day above ground is a good day"http://www.farmersamm.com/
Reply:Using the wrenches as a torch holder is genius. I'll certainly be using this trick.
Reply:I like it!MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:I don't need no stinkin' rotator!!!!!Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:That's great, but I can't fight this sudden urge to run out and buy a comic book...City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by tanglediver That's great, but I can't fight this sudden urge to run out and buy a comic book...
Reply:Dang Alfred just drove the price of garage sale wrenches sky high by increasing demand.I shudder to think of what his precision grinding setup will look like.  If he can't get Chinese slave labor Alfred will probably employ child labor working for comic books.
Reply:Another awesome documentary by Alfred Productions! And boy did you just give me a great idea. . .MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:So that's how the pros do it...
GMT+8, 2025-12-30 11:50 , Processed in 0.151983 second(s), 18 queries .
