Lincoln Weldanpower
发表于 2021-8-31 22:39:45 | 显示全部楼层 |阅读模式
This is not mine!Found this on my local craigslist.I am trying to find out more about it and inform the seller that he needs to fix his pictures!Heres the link:http://fortwayne.craigslist.org/tls/1289824256.html#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:What ever an arch welder is...Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:For overhead welding??I like the plumbers tape gas tank strap.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Hey he's almost finished with his current project. Time to move on to the next while all the stuff is still fresh in his head.
Reply:OK guys!I posted it here, so someone else will come and get it, I need a vacation! Duane, I just did mine with plumbers tape, couldn't find a better alternative at the moment! Besides ya'll, I still have that first one to put together yet!Last edited by Ken Dennis; 07-26-2009 at 10:39 PM.#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Originally Posted by Ken DennisDuane, I just did mine with plumbers tape, couldn't find a better alternative at the moment!
Reply:Well, my other two choices where duct tape or bungee straps!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Duct tape fixes everything!So, do you have new ones coming or going to fab them yourself?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Haven't decided yet! I have to go to my steel supplier in a couple of days to pick up some stuff for some new orders, I'll see what they have available to fab some out of!But, since I need to put Lucky to work this week, what I have will have to do for now!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:The "arch" welder jumped out at me too. So did "in the picks below".I seen a welder in Ohio for $100. It was powered by a Wisconsin engine, something like a VH4D I imagine. I thought about going and getting it since I have the parts I would need to fix it. But then I came to my senses.
Reply:I have a lincoln weld and power. its much larger than what that looks like its a 2 cylinder 18 horse onan. i had to work on it a bunch to get it runnin but now it runs pretty damn good, i use it daily for side work. It says on the plate on mine someone can weld while someone else can use the power outlets almost a dual genset but with limited power dependent on amps set for welding. Good machine i dont think i would buy another one though. More for farm use and what not im looking for a 200 to replace it.
Reply:Well!He fixed the pics and started a new add!http://fortwayne.craigslist.org/tls/1302264685.html#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2025-12-30 11:50 , Processed in 0.100388 second(s), 18 queries .
