Welding DVD's
发表于 2021-8-31 22:39:45 | 显示全部楼层 |阅读模式
I have five how-to DVD's:Flux Core Arc WeldingGMAW (MIG) Wire FeedArc Welding IArc Welding IIOxy-Act WeldingThese are the one's with Steve BleileNorthern Tools sells them for $25 each, I've seen them for more at other sites.  $55 for all five, free shipping.
Reply:Sold.
Reply:FYI, this is the Miller reference I had spoken about. I have to put a Cow Bell on it; I put it down and can’t find it for weeks. I have it set for 1/8 in steel. As you can see, it gives the recommended current, voltage, wire speed, shelding gas and wire diameter. I’ve found it to be very helpful, giving good results. 1/8” stock is 0.125 inches tick. At 1 amp per 0.001 inch that would be 125 amps as the suggested starting current. The calculator recommends 140-150 amps. I’ve tested, welding a 1/8 “ T fillet using these settings, 140 amps gives sufficient penetration to cause the back side of the joint to slightly melt through, 150 amps may be to much. Now that I’ve tweaked the power supply another notch I need to test with ¼ “ stock. The recommended current is 180-190 amps. Attached Images
Reply:I thought you were WELDING DVD'sThat would be impressive!!!!!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Arc only, right?
Reply:when I saw that I wondered what the heck was going on there yesterday lol
GMT+8, 2025-12-30 13:43 , Processed in 0.116054 second(s), 18 queries .
