Miller Spoolmatic 3
发表于 2021-8-31 22:39:43 | 显示全部楼层 |阅读模式
Miller Spoolmatic 3.  $350.00 OBO (plus shipping)I bought this as a backup to my Spoolmatic 2 I have in my shop connected to the WC-3 Contactor.  I had a problem with my wire feed rheostat (actually 2 stacked rheostats) that's mounted in the gun.  A clip came out, rendering it inoperable.  Then it broke.  A new rheostat was over $300.  I found one on eBay for a little over $200.  Repaired my Spoolmatic 2.This Spoolmatic 3 appears to have seen light use.  The friction plate that holds wire tension on the spool shows very little wear.  Inside the nozzle holder is not all gunked up.  the nut that holds the contact tube in place is not messed up with weld spatter.  There is paint overspray on the housing from the previous owner.  Cables are 30' long.  The shielding gas hose is 35' long.  The gas hose does have a pin hole in it about mid way.  I peeled off some duct tape on the hose and found it.  Simple fix with a double barb brass hose connector. I have marked it with a wire tie and white paint stick.The Spoolmatic 3 has a 14 pin connector and it contains the control pc card within the body of the gun.  It can be connected to any Miller welding power source that is Constant Voltage and has the 14 pin connector on the front, like the XMTs, CPs, or Millermatics w/14 pin connector like the MM200 did.Shipping weight will be about 25 lbs.  I ship UPS.  My Zip code is 17112 if you would like to go to the UPS web site to calculate shipping. Attached Images
Reply:Sold.
GMT+8, 2025-12-30 11:50 , Processed in 0.173852 second(s), 18 queries .
