查看: 22|回复: 2
New Tig Welder Quick question.
发表于 2021-8-31 22:39:40 | 显示全部楼层 |阅读模式
Just got a new Lincoln Precision Tig 225. I have been reading alot lately and noticed that most recommend a gas lens for it. I have been doing alot looking and am not totally sure what all i need. It has the air cooled 17 torch. I have found the gas collet. http://weldingsupply.com/cgi-bin/spi...||1|756
新手上路
Rank: 1
发表于 2021-8-31 22:40:27 | 显示全部楼层
5.99i think i have found the nozzle but i am not sure what the external threads are for on the nozzle. http://weldingsupply.com/cgi-bin/spi...||1|756
新手上路
Rank: 1
发表于 2021-8-31 22:41:07 | 显示全部楼层
1.25Is there anything else that i need for the setup? I read something about a seal? I cant find anything on weldingsupply.I would assume i need to buy the different sizegas collets for the different size tungsten.Thanks for the help.Krank
Reply:get the stubby gas lens kit from HTP Americahttp://www.ebay.com/itm/Stubby-Gas-L...item20dab56630it will "shrink" the torch head to almost the size of a 9/20 torch.  It has everything you need, including the needed teflon insulatorLast edited by Oscar; 11-16-2013 at 09:59 PM. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:I've been using a Weldcraft CS310, and a WP 20 for years now (water cooled torches) but as I recall from my air cooled torch days, you'll need the gas lens collet body, collet, torch insulator (white plastic piece), and alumina cup.  It might be easiest to drop in at your local welding supply shop and tell them what you are converting.  They should be able to hand you the right parts lickity-split.  Alternatively, this page has the necessary parts you'll need to piece it together.  You'll have to match a few parts, but fairly easy.  http://www.arc-zone.com/index.php?ma..._20_51_191_310Miller Dynasty 200 DXMiller CP-300 with 30A feederHypertherm Powermax 900Oxy-fuel w/Harris torchesScotchman Glide-in bandsawMonarch 10EE latheEmi-Mec Autoturn latheDeckel FP2NC milling machinePro-Tools 105 Bender
Reply:http://www.millerwelds.com/products/...p?model=M00313 click on spec sheet and get a parts diagram break down. the 17 is now a a-150 since Miller bought Weldcraft (I did not know this). Been a while since I ordered torch parts for my Weldcraft torches.
Reply:ordered the kit. thanks guys
GMT+8, 2025-12-17 11:06 , Processed in 0.273927 second(s), 18 queries .
