Prostar mig gun?
发表于 2021-8-31 22:39:40 | 显示全部楼层 |阅读模式
Need a new mig gun for my Lincoln 180, mine has a cut in the outer casing.  Hasn't been a problem because I've only used flux core up to now, but going to get into gas shortly.  Praxair quoted me $165 on a Prostar, and list is $195.  It's my understanding they are Bernard?   Thoughts and input appreciated.
Reply:They are a Bernard style. I have one and works well I also use a Bernard at work. Bonus
Reply:Thanks for the input! Originally Posted by fab_man21They are a Bernard style. I have one and works well I also use a Bernard at work. Bonus
Reply:Can get a Bernard on eBay for  $100 shipped. Just FYI, the outer casing does not hold the gas in, the inner hose does that. My M-25 gun got cut up on the edge of SS sheet metal. I pulled the gun end off and slid a section on heat shrink tubing on and shrunk it. It has been working fine for over a year.
Reply:Originally Posted by dellwasNeed a new mig gun for my Lincoln 180, mine has a cut in the outer casing.  Hasn't been a problem because I've only used flux core up to now, but going to get into gas shortly.  Praxair quoted me $165 on a Prostar, and list is $195.  It's my understanding they are Bernard?   Thoughts and input appreciated.
Reply:Not to Canada, shipping kills that.  Mine is cut down to the inner liner, so don't think that would work.  Thanks for the tip though.  Originally Posted by walkerCan get a Bernard on eBay for  $100 shipped. Just FYI, the outer casing does not hold the gas in, the inner hose does that. My M-25 gun got cut up on the edge of SS sheet metal. I pulled the gun end off and slid a section on heat shrink tubing on and shrunk it. It has been working fine for over a year.
Reply:Check out some Tweco guns..  http://www.ebay.com/itm/180Amp-MIG-G...item2ebc9415caLast edited by brucer; 11-18-2013 at 11:26 AM.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
GMT+8, 2025-12-30 11:50 , Processed in 0.183668 second(s), 18 queries .
