First flux core bead with new lincoln pro mig 140
发表于 2021-8-31 22:39:36 | 显示全部楼层 |阅读模式
Reply:Yep.Grind that rust off.
Reply:I know. Its a lincoln so knew it would be good. I was impressed at how easy it was to learn. Was a simple thing to do
Reply:keep practicing, eventually you'll get it down.
Reply:Originally Posted by crazyweldinfoolI know. Its a lincoln so knew it would be good. I was impressed at how easy it was to learn. Was a simple thing to do
Reply:looks a little cold. a focused pic would be a big help.i.u.o.e. # 15queens, ny and sunny fla
Reply:Spool up the .025 it came with, reverse the polarity and get a bottle of CO2. I just got a bottle the other day and it welds as good as C25 in my 140. You'll need the CGA 320-580 adapter for the regulator ($20)Whoever decided flux core should be used in mini-machines should be flogged with a chain.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
GMT+8, 2025-12-30 11:51 , Processed in 0.071161 second(s), 18 queries .
