Tubing Roller homemade and powered
发表于 2021-8-31 22:39:35 | 显示全部楼层 |阅读模式
I bought dies from swag offroad very economical and nice dies used their bearings and shaft and the rest was up to me. It works great and the horrible fright pipe threader is OK.  I have about $350.00 total with dies and I am pretty darn sure its stronger than most manual benders available
Reply:Did you make the plates yourself? I guess you did. Was wondering how heavy pipe or tubing can you roll. You did a good job. I build a lot of my own tools also. I'm always on the lookout for a hi torque motor. Just bought a pair of power chair motors. Using one to build my welding positioner.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Originally Posted by blawlessDid you make the plates yourself? I guess you did. Was wondering how heavy pipe or tubing can you roll. You did a good job. I build a lot of my own tools also. I'm always on the lookout for a hi torque motor. Just bought a pair of power chair motors. Using one to build my welding positioner.
Reply:Really nice looking tubing roller! Can you post any pictures of what you have rolled?
Reply:Good job, looks very professional.  What die sets did you get from swag?
Reply:I want to see bend pictures!!!
Reply:Here is a kayak rack made from 14g 1" I will post some more later
Reply:Great looking roller. We don't have one but was thinking of building/ buying for square tubing along with a bender.  Thanks for posting.   Like that rack on the 4 wheeler.
Reply:Also like the way you Mage the metal along the walls of your building.  Looks like a very nice shop
Reply:Originally Posted by richeyAlso like the way you Mage the metal along the walls of your building.  Looks like a very nice shop
Reply:can you post pics on how the harbour freight pipe threader mounts to that shaft. I have a manual one that I haven't used cause I really dont have the floor space to permanetly mount it somewhere.93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:[QUOTE=Anthony83;3602201]can you post pics on how the harbour freight pipe threader mounts to that shaft. I have a manual one that I haven't used cause I really dont have the floor space to permanetly mount it somewhere.[/QUOwhen you order your dies from swag tell them you need the shaft, then you just thread the shaft with the 3/4 threader and when you get it where you need it weld it to the shaft make sure and order extra bearings for the center die you will need to drill holes in the housing to mount bearings for the shaft. Manual rollers are for those that are glutens for punishment.your avatar is pathetic.
Reply:Just curious, will that setup bend up to a 90° without rolling or just using the Jack pressure alone?Sent from my DROID RAZR using Tapatalk
Reply:First off I don't need dies from Swag and secondly if you don't like my avatar don't Fakin look at it. And by the way if Marvin "Popcorn" Sutton was still with us he too would say "**** YOU!"Pic removed by mod. (I'll let it slide in the avatar, but the pic adds no value to the forum)[QUOTE=g-man;3602551] Originally Posted by Anthony83can you post pics on how the harbour freight pipe threader mounts to that shaft. I have a manual one that I haven't used cause I really dont have the floor space to permanetly mount it somewhere.[/QUOwhen you order your dies from swag tell them you need the shaft, then you just thread the shaft with the 3/4 threader and when you get it where you need it weld it to the shaft make sure and order extra bearings for the center die you will need to drill holes in the housing to mount bearings for the shaft. Manual rollers are for those that are glutens for punishment.your avatar is pathetic.
Reply:Hey anthony83 you need to talk to people like they are standing in front of you, and if you did you would probably have enough space by now to mount your tubing roller.
Reply:I'm gonna be the bigger person here, but think before you post an uneeded comment about something that has nothing to do with the topic beeing discussed.93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:I'd still like an answer to my question if possible G man... thanksSent from my DROID RAZR using Tapatalk
Reply:Originally Posted by JWDESIGNSI'd still like an answer to my question if possible G man... thanksSent from my DROID RAZR using Tapatalk
Reply:Originally Posted by Anthony83I'm gonna be the bigger person here, but think before you post an uneeded comment about something that has nothing to do with the topic beeing discussed.
GMT+8, 2025-12-30 11:52 , Processed in 0.069359 second(s), 18 queries .
