Miller (liquide) and Canox Tig/Stick Welder?
发表于 2021-8-31 22:39:32 | 显示全部楼层 |阅读模式
Hey everybody! i am interested to know more about this!Is the blue stick welder a miller? The top part (canox) is also a miller. I remember the salesman slip was tucked in the canox welder and said it was from 1965.Also could you tell me how to hook up the ac and dcen and dcep roughly with the welder?the Canox tig rectifier has a switch AC/DC:roll eyes:VictorPraxairAir LiquideMillerLincoln Electric
Reply:It is not an AC/DC welder and I'm not positive it's a miller. Look at the bottom picture, it says Industrial AC welder. The Canox box is a high frequency for AC TIG.
Reply:wow It does look similar to a miller but im not sure ive never seen one that old!! not sure when miller started making the thunderbolts? I was thinking early 80s..?  and I believe the above poster is right its ac and some kidna hi freq box... let us know how it works!
Reply:Yeah, it's miller. AC only machine.An 88 model if memory serves. The HF box is miller too. It's not a rectifier.Most likely made in the 60s as you were told, possibly earlier. Dunno right this second.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Miller 88.  See post #251:  http://weldingweb.com/vbb/showthread.php...l-using/page11"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Thanks all for your feedback! however it can do DC tig because it has a toggle switch with DC and AC. When i bought it it came with a Air Liquide tig torch (assuming you can't get parts and consumables for.VictorPraxairAir LiquideMillerLincoln Electric
Reply:The Canox box looks to be a Miller HF-15.  Manual here:  http://www.millerwelds.com/om/o610c_mil.pdfThe AC/DC switch is set according to what type of power source you are using.  It is NOT a rectifier.  It just switches a capacitor between two points in the output circuit."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:so a 1 phase power out of town is going to be AC? so if it is AC then i put the toggle on AC? Also you guys can tell me how to use DC with it or is it possible?VictorPraxairAir LiquideMillerLincoln Electric
Reply:"Mains" electricity is AC. A welder can be AC or DC or both.  It must have rectifiers to convert the AC welder output to DC.  (Edit: unless it's a rotary DC generator type welder). The Miller 88 is an AC welder (unless someone converted it), so you would set the switch for AC.  If you had a welder like a Dialarc, you could connect either AC or DC and set the switch accordingly.Last edited by Oldendum; 04-11-2015 at 01:39 PM."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Ok that makes sense. so switching the cables doesn't do anything. there is a plug on the back of the welder that connects the power to both of the welders by the way!I had a family friend who is a welder come by and help me with the proper setup, and he said if you put the cables and connections a certain way it can work with both DCEN DCEP and AC. I understand that the top part is not a rectifier now.VictorPraxairAir LiquideMillerLincoln Electric
Reply:Download the Miller HF-15 manual at the link I posted.  It will give you some info."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2025-12-30 12:40 , Processed in 0.071700 second(s), 18 queries .
