DIY Fume extractor with Canfan
发表于 2021-8-31 22:39:31 | 显示全部楼层 |阅读模式
So I picked up a "canfan" 1019cfm 10" nice and quiet. $45 so naturally I couldn't pass it up. http://www.amazon.com/Can-Fan-Inline.../dp/B002SQRNR2 I will be building a fume extractor with it....any input?Last edited by FitnFused; 03-06-2015 at 05:30 PM.Reason: add link
Reply:Good luck, please let us know how it turns out.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Originally Posted by FitnFusedSo I picked up a "canfan" 1019cfm 10" nice and quiet. $45 so naturally I couldn't pass it up. http://www.amazon.com/Can-Fan-Inline.../dp/B002SQRNR2 I will be building a fume extractor with it....any input?
Reply:Yeah got used but like new. Posted so yall could see specifications
Reply:I'm interested as well.  Are you planning to build a movable arm, fixed duct work to the center or affix it on a wall?   Sounds like a speed controller can be pricey with the can fan's, but I'm not sure if it's really needed.
Reply:I had everything picked out at home depot and it totaled 200+ which is very fair. Ducting adapters/flexible duct hose etc. I decided to hold of a bit and see what i can dredge up at the swap meet as far stuff to aid fabrication of a movable arm.  I scored the fan cheap there so i'll try and finish it there.It didn't even dawn on me to add a speed controller......THANKS!!Lincoln PowerMig 200AHP 200x 3rd Gen.Miller 211 AASMiller Digital Elite "POWMIA"Victor Oxy SetLotos ltp5000d
Reply:http://www.parts-express.com/parts-e...m_campaign=plaLincoln PowerMig 200AHP 200x 3rd Gen.Miller 211 AASMiller Digital Elite "POWMIA"Victor Oxy SetLotos ltp5000d
Reply:You could always use fixed speed on the fan and just put a damper in to control air flow.Multimatic 200Ellis 1800Haberle S225 9" cold sawMM 300;  Spoolmate 30A w/ WC-24TB 302GDynasty 280 DX Tigrunner
Reply:Originally Posted by DrooopyYou could always use fixed speed on the fan and just put a damper in to control air flow.
Reply:Where is everyone venting their fumes to? I have two vents built into the peak of my garage. Looks to me that I could just extend the flex hose up and connect to one of them.  Comments?
Reply:I just vent into the actic space of my shop.I have a ton of ventilation up there so I don't worry about it.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:My shop is only 24'x30' with an open ceiling - no attic. The vents really don't do much in the way of reducing the temps in the summer. Normally have the roll-ups open and have a couple of windows for cross flow also. I found some 8" flex hose at an auction that's about 25' in length. With my extractor tube and an inline fan, I think I can duct everything right out the existing vent. We'll see.
Reply:You got a screaming deal on that fan if it's actually CAN brand. Try to keep the amount of ducting on the inlet side of the fan to a minimum, as well as using as little flexible duct as possible. Rigid ducting flows much better and is actually cheaper than a high quality flex duct.
Reply:What I use. 8 inch duct, harbor ft yellow ventilator, barbecue was free from neighbor.Swings up out of the way, so wifey can park her car in garage.Charl
Reply:Don't they say not to restrict the flow of these units? My Grizzly is 570cfm and I am looking for a smaller unit. It is just overkill in so many situations that I don't even use it.
Reply:Yeah def over kill....but it was cheap so I grabbed it real quick. The build has been on hold but that barbecue lid idea has me revisiting ideas ...love that lolThere's actually a lincoln hose for sale here on site... $200 to the houseI'm about to go for.it.Last edited by FitnFused; 04-12-2015 at 10:29 PM.Lincoln PowerMig 200AHP 200x 3rd Gen.Miller 211 AASMiller Digital Elite "POWMIA"Victor Oxy SetLotos ltp5000d
Reply:Right on...thanks.Lincoln PowerMig 200AHP 200x 3rd Gen.Miller 211 AASMiller Digital Elite "POWMIA"Victor Oxy SetLotos ltp5000d
GMT+8, 2025-12-30 12:39 , Processed in 0.102746 second(s), 18 queries .
