Bending sq. tube w/round dies?????
发表于 2021-8-31 22:39:30 | 显示全部楼层 |阅读模式
I'm looking a buying the HF 16 ton tube bender (which I need like a hole in my head, but...) My question is can you bend sq. tube with the round tube dies that come with the HF bender or will I have to buy / make sq. tube dies???
Reply:You will have to make sq. dies.   But they can easily be done on a band saw.
Reply:One other thing to remember is that it is a PIPE benderTons of posts about the difference betwixt a Tube bender and a Pipe Bender.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by GabZipYou will have to make sq. dies.   But they can easily be done on a band saw.
Reply:Originally Posted by d94joncapardon a noobs ignorance but do you have any specifics on best practices for making square dies?
GMT+8, 2025-12-30 12:39 , Processed in 0.116127 second(s), 18 queries .
