Parma Work-A-Matic Bandsaw
发表于 2021-8-31 22:39:29 | 显示全部楼层 |阅读模式
I came across one of my neighbors selling this Work-A-Matic bandsaw. He is asking $700 I was wondering if it was worth it or should I pass. It looks to be in decent condition, maybe needs a new power cord.
Reply:I'd low-ball him.One of my catalogs shows a similar machine listing for over $4K.Rex
Reply:I got it for $500 I will post up some more pictures later. I am not sure about the power I think it is 3 phase. Not sure what i got myself in here......
Reply:Originally Posted by richie v6I got it for $500 I will post up some more pictures later. I am not sure about the power I think it is 3 phase. Not sure what i got myself in here......
Reply:If the motor is 3 phase no big deal, you can get a single phase input 3 phase output VFD to run the motor which will also give you the ability to vary the speed of the saw depending on what you are cutting. I have a VFD on my lathe and milling machine and wouldn't want to work with out it. Look up either Automation Direct or Teco to find a reasonably priced decent VFD.
Reply:Originally Posted by jncarusoIf the motor is 3 phase no big deal, you can get a single phase input 3 phase output VFD to run the motor which will also give you the ability to vary the speed of the saw depending on what you are cutting. I have a VFD on my lathe and milling machine and wouldn't want to work with out it. Look up either Automation Direct or Teco to find a reasonably priced decent VFD.
Reply:I live in Parma Michigan the furtwranglers use to make these in alittle shop Dake bought them out  [part are ready easery to get but pricey I have had one for 5 years works good
Reply:Yes it's 3 phase. That looks like a sweet deal.“Life is not a journey to the grave with intentions of arriving safely in a pretty well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming ... WOW! What a ride!”
GMT+8, 2025-12-30 12:40 , Processed in 0.099135 second(s), 18 queries .
