Where to get an oil pressure sending unit?
发表于 2021-8-31 22:39:25 | 显示全部楼层 |阅读模式
Where would be a good place to get an oil pressure sending unit for an SA200? NAPA?
Reply:Either that or O'Rielly Auto or Auto Zone.  Tell them 'make' or 'break' on pressure increase (which ever is needed), pressure setting desired and connection pipe thread size and any of them should be able to fix you up.I take it this for the Auto Idler power supply?  If so it needs to be 'make' on pressure increase and needs to be a fairly low setting (4-6psi) as minimum idle oil pressure on the F-162/163 is 7psi.Last edited by duaneb55; 08-21-2009 at 11:20 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Its for the blue light. Thanks for the info about the pressure. I would hate to get one that didnt work,
Reply:Same basic circuit.  Oil pressure switch closes to provide power to the Auto Idler switch and light the blue/green Oil Pressure light at the same time.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-30 12:40 , Processed in 0.084544 second(s), 18 queries .
