Looking for a Miller Bobcat part.............
发表于 2021-8-31 22:39:25 | 显示全部楼层 |阅读模式
I am looking for a Miller Bobcat 225G Plus rotor or entire generator.  I will consider purchasing a entire Bobcat unit that has a blown engine or no engine.Thank You in advance, Dave
Reply:If Larry (weldersales) or TJ (onanparts.com) don't have one or you can't otherwise find one, I have a great source for reasonably priced and high quality re-winds.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by 7A749Good luck.Commonplace with those machines. Weldersales on here will have one. Who knows how much tho.You're best off getting another machine for what you are going to spend in time & labor fixing the broken one.That, or keep an eye on ebay & craigslist.
Reply:Thanks Duaneb55,I am really interested in your source with the re-winds.  Can you help a brother out?  I am kind of in a spot with this machine.Dave Originally Posted by duaneb55If Larry (weldersales) or TJ (onanparts.com) don't have one or you can't otherwise find one, I have a great source for reasonably priced and high quality re-winds.
Reply:Here ya go.http://www.eurtonelectric.com/They have an on-line quote form but you could also give them a call and they may be able to tell you on the spot.  They've done a number of generator stators for a colleague at a fraction of the cost of new and they've been top quallity.Might give Larry Burross at Applied Equipment a call too. (214-630-9353)Hope you can get it worked out.BTW - where are you located?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thank you for the info Duane.I am going to follow up with these folks you have recommended and I am sure I can get this problem worked out with you help.  I live in Sullivan, Missouri, about and hour southwest of St. Louis.Again thank you Duane. Originally Posted by duaneb55Here ya go.http://www.eurtonelectric.com/They have an on-line quote form but you could also give them a call and they may be able to tell you on the spot.  They've done a number of generator stators for a colleague at a fraction of the cost of new and they've been top quallity.Might give Larry Burross at Applied Equipment a call too. (214-630-9353)Hope you can get it worked out.BTW - where are you located?
Reply:I'm told you should ask for John.  If John isn't available you can talk to Rick.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-30 12:40 , Processed in 0.103490 second(s), 18 queries .
