Needs tip for isolating heat to small area.
发表于 2021-8-31 22:39:14 | 显示全部楼层 |阅读模式
I need to heat a 5/16" steel rod to make a sharp bend, but the spot is within about 1-1/2" of a brazed joint. How can I make sure I don't loosen the joint when heating?
Reply:Put a wet rag around the brazed joint.
Reply:Doh! That was too easy. Thanks.
GMT+8, 2025-12-30 15:33 , Processed in 0.104373 second(s), 18 queries .
