Hey guys I'm in the process of building a bumper and need to bend some 1 1/4 tube so I get a harbor freight bender and the tube starts to bend and then it just kinks so what am I doing wrong or is the ool just not capable and should I just have my tubes bent at a shop with a profesional machineVictor torch Lincoln Idealarc DC 250 Lincoln LN 7 wire feederMilller WC 200 spool gunLincoln Idealarc 250 ac/dcColosal Tech Cut 50
Reply:Do you have a tubing or pipe bender? Are you bending tubing or pipe?
Reply:I'm using a harbor freight hydraulic bender and its pipe I guess prob about 3/16 wallVictor torch Lincoln Idealarc DC 250 Lincoln LN 7 wire feederMilller WC 200 spool gunLincoln Idealarc 250 ac/dcColosal Tech Cut 50
Reply:If I can help with a JMR Manual Tube bender let me know. A tube bender wraps the tube around the die rather than pushing the die into the center of the bend. I assume this is the style bender you bought from HF. This is the JMR Tube Bender. Let me know if you have any questions.http://www.jmrmfg.com/featured-tools...0-tube-bender/"I Build Stuff"www.jmrmfg.comwww.509media.com
Reply:pipe benders work ok for bending tube to a point but it will always kink when you go too far. the pipe bender was not designed to bend tubing. the dye is not designed to bend the tubing correctly, if you only make small short bends it will work.
