just got a powcon 300sm, no power plug on cord, and weather it works or not is ????? So I pulled the cover off and i see all the buss bars are set up for 230 volt, would i assume that is single phase? and is the high volt (460 volt set-up) for 3 phase? I will be running it (I hope) on 220 single phase. so hopefully i can just wire the plug on and plug her in.....another question is the togle sw. on the control panel has 3 positions SMAW....GMAW SHORT....and GMAW... so what is gmaw short used for? Thanks in advance.
Reply:Gmaw short circuitAnd the other is for gmaw sprayI believe it will "auto link" single or three phaseThere no cord at all? Or was the cord cut?With original cord, you connect the black and white to hot and green to ground and don't hook up red. For single phase operation
Reply:If you use the spray position, be sure your tip is recessed, and that you have the machine set right. The first time I tried the spray setting I ruined a tip.
Reply:yea, just the end plug was removed, it has about 8' of power cord (4 conductors) and no end plug....with no feeder, i will just be doing SMAW to see how it goes....wire feeders are more $$$$ than the welder power supply itself, about 3 times more...WHY is that? that just does not seam right......
Reply:keep an eye on ebayDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Originally Posted by 1awert1just got a powcon 300sm, no power plug on cord, and weather it works or not is ????? So I pulled the cover off and i see all the buss bars are set up for 230 volt, would i assume that is single phase? and is the high volt (460 volt set-up) for 3 phase? I will be running it (I hope) on 220 single phase. so hopefully i can just wire the plug on and plug her in.....another question is the togle sw. on the control panel has 3 positions SMAW....GMAW SHORT....and GMAW... so what is gmaw short used for? Thanks in advance.
Reply:Here is the link to the 300SM owners manual I have on Google Drive.https://docs.google.com/file/d/0BzZ5...it?usp=sharingLast edited by soutthpaw; 04-08-2013 at 11:39 AM.Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:Exactly. Great machines but no parts sources anymore. There is arcon but u will pay more for most parts than u can buy a good replacement machine for...Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:Three phase power will give you 300 amps. single phase power will only give you 200 amp of welding power. Just like all the newer inverter welders, on single phase you have to power the right two of the three input wires for the welder to even power up and the fan run.
Reply:Originally Posted by soutthpawExactly. Great machines but no parts sources anymore. There is arcon but u will pay more for most parts than u can buy a good replacement machine for...
Reply:[QUOTE=cope;2493691]Is Arc-Products gone?[/QUOTLE]. Yep about a year ago. Bought out by another company. Hence no more online manuals or anything. I got the PDF of all the manuals they used to have onlineTiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:[quote=soutthpaw;2494071] Originally Posted by copeIs Arc-Products gone?[/QUOTLE]. Yep about a year ago. Bought out by another company. Hence no more online manuals or anything. I got the PDF of all the manuals they used to have online
Reply:Late to the discussion, I just purchased a powcon 300ss. In addition to the bus bars, I needed to flip a circuit board to use with 220 power. The welder is still a work in progress, so let mew know how yours works out. Good luck
Reply:Did you get your 300 going?Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan |
