welding cart first project
发表于 2021-8-31 22:39:01 | 显示全部楼层 |阅读模式
I used 1.5" angle iron and flat bar to build the frame.  The handle and bottle holder is 1" sqare tubing. All metal is 1/8" thick.  It is 30" long and 18" wide.  I allowed 8" for the bottle to sit on, so the top frame where the welder sits is 22".  I welded 1/2" bolts for the main wheel axles and moved them forward about 9" for a better center of gravity for moving it outside in the gravel.  The hangars are just 1/4" bolts welded on with the heads out.  Other than the handle angled at 45 degrees everything else is just built with a square and is 90 degrees......I wish I would have learned to weld years ago, it's kind of fun!! Attached Images
Reply:Looks good!! Two thumbs up!!Sent from my iPhone using TapatalkQualified & experienced at welding scrap metal
Reply:Damn nice little rig ! About 10.000x better than that garbage they try to sell you at the shops.Put a Snap-On sticker on it and some retard will offer you $3500(without the tools)Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:That looks very handy!!JackFort Loramie, OhioMilermatic Autoset 180
Reply:Looks good.Sent from my iPhone using TapatalkLincoln Pro Mig 180HF Stick/Tig Inverter WelderLincoln AC225s
Reply:Well aint that slick. Nice work!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Kinda fun? Kinda fun?!!!!! (&*%^%$#*()__^$#@!!!!!! It's Dammn Fun!!!!!!!  Hobart 125 EZHobart Handler 140Everlast STH 160Generic 210 Amp Welder/GeneratorHobart Air Force 500i plasma cutterChinese 50 amp plasma cutter! Youtube Channel : Henrymac100
Reply:Originally Posted by HenrymacKinda fun? Kinda fun?!!!!! (&*%^%$#*()__^$#@!!!!!! It's Dammn Fun!!!!!!!
Reply:Nice Job for a first welding cart!
Reply:Looks great and clean work on it, quite impressive for a first. Like the use of the nails and very nice yellow color. Great job!
Reply:The welder is a 140 mig pac Canadian tire special.  I started the job using .035 flux core, then switched to .025 straight wire when I got my bottle of 75% argon 25% co2 gas.  The gas made very nice clean welds, compared to the flux core wire.....well once I finally remembered to switch polarity!!
Reply:Very Nice!!!!  Build one for me too ok?nice!!!!Miller Big Blue Air PakMiller 350P, Python GunHyperthermsSpool gunsMetabo GrindersWe "dooit" as a family...."a family that sleds together stays together"......from sleddin to campin to 4 wheelin to workin.....gotta enjoy life somewhere!
Reply:That's a nice'n!"All of this and some of that's the only way to skin the cat!"
Reply:Great Job!
GMT+8, 2025-12-30 13:45 , Processed in 0.174417 second(s), 18 queries .
