welder not wanting to weld
发表于 2021-8-31 22:39:00 | 显示全部楼层 |阅读模式
my lincoln is giving me problems it wont strike an arc? whats going on and what do i need to do?
Reply:Originally Posted by 7FeatheredDCmy lincoln is giving me problems it wont strike an arc? whats going on and what do i need to do?
Reply:Hello and welcome.Kind of an open ended question like " My truck is broke, what's wrong with it?"It would really help if we knew just a bit more info. Last time I checked Lincoln made more than one welder ( yes I know the SA 200 fans might disagree with that...) The more info you give us, the better the help can be..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Nope, you got it all wrong.  Either the laughingpin fell out of the gigglingstop, or it's missing a skyhook. Originally Posted by BurpeeCheck the frazom internator, make sure the tungsten is sharp and replace the roller assembly.
Reply:Originally Posted by dellwasNope, you got it all wrong.  Either the laughingpin fell out of the gigglingstop, or it's missing a skyhook.
Reply:Originally Posted by jontheturboguyNo no no!  Both of you are way off.  Its the metric diode clutch that shares AC power to the transformer bearings.
Reply:I sent in a specialist to straighten him out.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:I thought this was going to be a thread about most of my past coworkers.
Reply:Originally Posted by AntiblingI thought this was going to be a thread about most of my past coworkers.
Reply:SOAB!  Forgot all about the transformer bearings, and it's a known problem... Originally Posted by MinnesotaDaveProbably this one ^^ since it's a metric problem Or Optimus Prime wants his transformer bearings back?
Reply:i had the EXACT same problem with my welder once.turned out to be the loose nut behind the stinger.
Reply:BUY A MILLER . Go here this will fix you right up. http://www.millerwelds.com/products/
Reply:You guys don't know anything... I had  the same welder problem once. Finally found the high lift fern docket have move behind the oval framistat. Quick fix. Went and got another six pack and alls well. Sent from my iPhone using Tapatalk
GMT+8, 2025-12-30 13:46 , Processed in 0.068997 second(s), 18 queries .
