Mounts and Brackets
发表于 2021-8-31 22:38:59 | 显示全部楼层 |阅读模式
Finally posting some work of my own. These were a few jobs back for one of the largest semi companies. These were first mig'd until I convinced the boss to let me tig them. This was a bad one, but I was laying the rest in so good that if it wasn't for the heat zone you wouldn't have been able to find the weld.Sent from under a Miller welding helmetLast edited by itslukedavis; 02-01-2014 at 07:47 PM.
Reply:Why didn't you weld the ends? Looks like you started after the tack. Also, fill the crater at the end of the weld.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Since the machine was as old as I am there was no turning it down anymore. So I had to tack the ends so they wouldn't melt through.Sent from under a Miller welding helmet
GMT+8, 2025-12-30 13:45 , Processed in 0.095420 second(s), 18 queries .
