8in bench grinder pedestal
发表于 2021-8-31 22:38:59 | 显示全部楼层 |阅读模式
I built this from scrap steel, I used 3/8inch plate to mount to the wall and the rest is 1/4 in angle and square tubing. The box behind the grinder is to collect the dust expelled from the ports. Attached Images
Reply:Looks nice and sturdy. Do you fill the spark box with water?
Reply:I will be adding water to the tray, I might also have to seal around the dust ports and openings to make it dust tight. The pedestal it self is solid, I bolted through the block to the outside with 1/2inch x 12 inch bolts. Thanks Steve
Reply:I wouldn't go thru the block itself if i were u, The seams would be better.....just my 2 cents........
GMT+8, 2025-12-30 17:22 , Processed in 0.096817 second(s), 18 queries .
