Tweco 211i or powermig 210mp
发表于 2021-8-31 22:38:58 | 显示全部楼层 |阅读模式
So I can't decide which machine to get. Need help deciding. Can somebody who knows about these machines give me their opinion on them.
Reply:http://www.bakersgas.com/THEW1004201.htmlThe Thermal arc weighs 20lbs more, is bigger, holds larger spools of wire.FWIWJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I can't really comment on the 210mp as I dont know anyone that has one yet, they look nice though! I have used a 211i and own a 252I, they are solid machines and the Fusion gun has turned out to exceed my expectations. I run mine on a generator mostly and has worked perfect for mig and stick. The Tweeco comes with lots of extras, the cart is also a great setup if you order that package. Having the ability to hold a larger spool of wire is a plus. I find the setup to be very quick and easy and with gloves can turn the knobs without any issue. if you can find a place that sells both ask them thier opinion, also if they have welded with both and which one does a better job on the process you are going to use the most.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:Jaws have you tried tig on it? I went to air gas and they will not have anymore 210 mp's til late May .
Reply:The TA211i tig welds very nicely. The TA tig torch is quite large though.  Get a torch setup from HTP and you are good to go.Multimatic 200Ellis 1800Haberle S225 9" cold sawMM 300;  Spoolmate 30A w/ WC-24TB 302GDynasty 280 DX Tigrunner
Reply:I messed with the tig function on the 252i when I first got it, I can't say there is anything spectacular about it in this area, it works like advertised on the test welds I did. I have not had any recent jobs that called for DC tig that my 185TSW could not handle, and am partial to using that machine.Good luck, I am sure you would be happy with either one. Tweco still has a free helmet promo going on.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:Can you use any tig torch on the 211i or does it have to be a tweco one? I hooked up my tig torch to it but I can't get it to start the arc. Does it need a trigger?
Reply:Originally Posted by acg1991Can you use any tig torch on the 211i or does it have to be a tweco one? I hooked up my tig torch to it but I can't get it to start the arc. Does it need a trigger?
Reply:Thanks I tried it with the mig gun and it  worked. Where can I buy a trigger/button for it?
Reply:You can also get the foot pedal and not have to have a switch on the torch.   Just throwing it out there.Multimatic 200Ellis 1800Haberle S225 9" cold sawMM 300;  Spoolmate 30A w/ WC-24TB 302GDynasty 280 DX Tigrunner
Reply:http://www.zoro.com/i/G7866415/?gcli...FUZafgodKhcAsghttp://www.restockit.com/anchor-sw1f...0-sw1f%29.htmlMaybe use the Zoro tools 20 % off to balance out the shipping.. (Edit...won't work because it takes $150. to get a discount) Here is how I handle the machine end.. $2.00 trailer plug (two sets) will allow for the tig, and mig to use the same 8 pin.. I swap my guns around, and don't want to mess with buying a bunch of 8-pins etc.. I am going to get some Velcro to hold the button on, tape get warm and sticky.. Machine is not here to worry about that anyway.. This is just all thrown together stuff. Ft pedal is good too, but the button is kind of nice too. I have other machines with a ft pedal, so kind of a waste for me.. If one shows up cheap,  I will grab it. Attached ImagesLast edited by Brand X; 04-15-2015 at 11:32 AM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Originally Posted by Brand Xhttp://www.zoro.com/i/G7866415/?gcli...FUZafgodKhcAsghttp://www.restockit.com/anchor-sw1f...0-sw1f%29.htmlMaybe use the Zoro tools 20 % off to balance out the shipping.. (Edit...won't work because it takes $150. to get a discount) Here is how I handle the machine end.. $2.00 trailer plug (two sets) will allow for the tig, and mig to use the same 8 pin.. I swap my guns around, and don't want to mess with buying a bunch of 8-pins etc.. I am going to get some Velcro to hold the button on, tape get warm and sticky.. Machine is not here to worry about that anyway.. This is just all thrown together stuff. Ft pedal is good too, but the button is kind of nice too. I have other machines with a ft pedal, so kind of a waste for me.. If one shows up cheap,  I will grab it.
Reply:Lol I'm confused how does that plug in to the machine. Can you take a close up pic of that plug.
Reply:Originally Posted by acg1991Lol I'm confused how does that plug in to the machine. Can you take a close up pic of that plug.
Reply:FWIW I was told at Praxair (Canada) that the 210's are getting a 14% price hike in the coming weeks. Just lettin you know what I was told. Pidge.Lincoln210mpHobart Handler 125...soldBoat battery and a couple coat hangers
GMT+8, 2025-12-30 13:47 , Processed in 0.095975 second(s), 18 queries .
