Welding certs
发表于 2021-8-31 22:38:56 | 显示全部楼层 |阅读模式
Hey guys so I wanted to see your input on stick 6g pipe and FCAW 3G and 4G plate  I'm not sure what cert to go for Or should I go for bothAngel
Reply:It all depends on your location, the type of work prospects in your location, your chance of passing, and your past work experience.  If you have lots of money to throw around and not in a rush to get to work, certainly get every possible cert you can get.
Reply:PIPE! screw structural Flux core lol In my honest opinion
Reply:If you want to go into structural construction work, those are the certs you’ll need. Make sure the 3-G, and 4-G are unlimited thickness!Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Go for both then you can weld both proces
Reply:Well I'm in Cali but I want to move to Omaha Nebraska and dice the 6g pipe covers plate also so idk what to doAngel
GMT+8, 2025-12-30 13:46 , Processed in 0.071821 second(s), 18 queries .
