got a new trailblazer 302 it smokes like a sombitch hen
发表于 2021-8-31 22:38:55 | 显示全部楼层 |阅读模式
my new 302 tailblar smokes like a sombitch when starting it is this common
Reply:If it's the Kubota, smoke from a diesel on start up isn't that unusual and should be expected.Last edited by duaneb55; 06-04-2010 at 12:05 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:If it's the Kohler gas engine, no, that's not normal.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:its the subaru
Reply:Does it still smoke after you push the choke cable back in????   You ARE pushing the choke cable back in after it starts, are you not????Is the oil level in the crankcase at the correct level?What color is the smoke?How long after running, does it still smoke???
GMT+8, 2025-12-30 17:21 , Processed in 0.104743 second(s), 18 queries .
