Advice on Thermal Arc 95S Stick/TIG Package
发表于 2021-8-31 22:38:54 | 显示全部楼层 |阅读模式
I am working on a 1967 Pontiac Tempest that needs some sheet metal replacement in the rear window area due to rust.  I have a small mig welder that I could use for this task.  It is a Millermatic 130XP 115 volt wire welder with a 25%/75% mix of gas.I have recently noticed advertising for the Thermal Arc 95S Stick/TIG package.  The price is around $400.  I believe that this is a 115 volt  DC only machine and therefore cannot TIG weld aluminum.  However, if could be used for welding the thin steel I would use in my sheet metal replacement project.  I would like to be able to do nice quality welds without burn through when replacing the sheet metal.     Any comments on the 95S Stick/TIG package would be welcomed.  ThanksRSOHC
GMT+8, 2025-12-30 13:45 , Processed in 0.097980 second(s), 18 queries .
