Is this what I think it is? (A Lincoln)
发表于 2021-8-31 22:38:52 | 显示全部楼层 |阅读模式
Saw this on a local buy & sell site advertising an equipment auction.Last edited by Eric N; 05-05-2010 at 09:39 PM.
Reply:From the control wheel I'd guess Hobart.  I see it has Detroit Diesel power and almost looks like something someone put together from parts with the generator divorced from the driver.  ??MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:good news is the local scrap yard will give me $0.30 per lb. as electric motor scrap.   other than that its an interesting conversation piece.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Scrap HELL!That's the perfect generator & control for a guy who wants to build a PTO driven machine on the back of a truck.The little Detroit is worth some dollars too if it runs.It's definitely not a factory made machine, and looks like somebody spent alot of hours making it up.
Reply:Yeah when I saw the polarity control and thought it looked like a Lincoln. But some other things looked off. I don't know much else about it, and the town the Auction is in is about 2hrs from where I live. It just so happens I will be there around the time of the auction. I think i'll go check it out, if the price is right (really low) I might wind up taking it home.
Reply:That's definitely a Lincoln machine, my SAE300 has the same controls on it. Job selector on the left, electrode polarity in the middle, and current control steering wheel on the right. RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25
Reply:Originally Posted by RobertDoubravaThat's definitely a Lincoln machine, my SAE300 has the same controls on it. Job selector on the left, electrode polarity in the middle, and current control steering wheel on the right.
Reply:Any updates on that old Detroit dinosaur machine?RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25
Reply:That looks to be  an early 1950's SA300 that had a 6 cylinder gas motor in it.  I believe someone junked the gas motor for the diesel. Since the diesel is much shorter, they just connected a drive shaft to spin the rotor.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:Originally Posted by Xtreme FabricationThat looks to be  an early 1950's SA300 that had a 6 cylinder gas motor in it.  I believe someone junked the gas motor for the diesel. Since the diesel is much shorter, they just connected a drive shaft to spin the rotor.
Reply:How much did it go for?RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25
GMT+8, 2025-12-30 13:45 , Processed in 0.107247 second(s), 18 queries .
