I have been welding pipe for twenty years withtout having to wear a hard hat now i have too.If anybody has a good used set up or can tell me what the best set up is that would be great thanks jim
Reply:Originally Posted by Pearl WeldingI have been welding pipe for twenty years withtout having to wear a hard hat now i have too.If anybody has a good used set up or can tell me what the best set up is that would be great thanks jim
Reply:I have hard hat mounts for my Jackson HSL100 hood and MSC hard hat. You can get the mounts through Jackson or MSC.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Might consider these. http://www.fibre-metal.com/m-hp-relp4.htm
Reply:The one I have by Miller for my Miller Elite is ok All are a PITA
Reply:i have the Model 4000 Quik-Lok knobs with my fibre metal hood. my favorite setup for a hardhat
Reply:Everybody(Jackson, Fibremetal, Miller, Speedglas) makes hard hat adaptor kits. My advice would be to make sure you get a light weight hood to mount to your hardhat. For some reason, I had lots of trouble with my hardhad falling off when I mounted one of my heavier hoods to it. My auto dark lens was right out. I even swapped out a glass fixed shade filter for a lighter plastic one to lower the weight of the hood. Once I did this everything worked fine. Just my $0.02.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector |
