Looking for a nozzle for marvel-schebler
发表于 2021-8-31 22:38:50 | 显示全部楼层 |阅读模式
I am in need of a nozzle for my carb. It actually broke off in the bottom of the carb. I was able to get it out with a great deal of luck.Here's a picture to show the part I need. I got the picture because I was calling it a power valve and turns out its called a nozzle.I don't know the # for the carb. I'll find the make or model and update. There are some numbers on the bottom of the float bowl that are 10-A and 355.If need be I can upload an image of the broken nozzle.I need #14 in the attached image. Its a long brass tube that is threaded.
Reply:Not looking anymore. Someone came and got my F162 and the carb that was missing the nozzle.
GMT+8, 2025-12-30 13:46 , Processed in 0.155826 second(s), 18 queries .
