Going after the above ground pool market now
发表于 2021-8-31 22:38:47 | 显示全部楼层 |阅读模式
More and more people are interested in handicap lifts for above ground pools  now.....SO if you remember the proto bases I made awhile back?  We are making them a part in the product line now so more thick aluminum to stick together....There are two designs a short and a long depending on the application needed....Last edited by B_C; 12-05-2013 at 01:18 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Nice work Bill, as always! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Yes. Definitely 1/8th filler. Money-Money-MoneyWeld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:My God those are beautiful welds! Bill I'm not sure you are even human, maybe you're from another planet.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:bet you were pumping the heat into that bugger, nice work!
Reply:Stud.
Reply:Originally Posted by zankStud.
Reply:Originally Posted by shovelonPillar
Reply:Only bad part, is that aluminum and chlorine don't go together well. I realized this when I pulled my$350.00, 2" electric Tsurumi water pump out of my pool. It has a lot of corrosion that I just can't get to disappear."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manOnly bad part, is that aluminum and chlorine don't go together well. I realized this when I pulled my$350.00, 2" electric Tsurumi water pump out of my pool. It has a lot of corrosion that I just can't get to disappear.
Reply:Beep Beep Bop Boo Beep.....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:By the way, AWESOME work!!! Originally Posted by weldermikeThanks buzzkillington!
Reply:I hope I can lay dimes like that some dayLincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
Reply:Tig welds look great! I'm just curious if on a job like this you might have considered mig instead. What considerations would you make in choosing one process over another? Just trying to learn why one might go with one or the other. Thanks!
Reply:Great work as always B_CMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:so are you manufacturing the whole enchalada? like above video shows?I'll be honest I've never heard or seen a wheel chair lift and couldn't understand the market for it? With an inexpensive above ground pool going for $2500, would someone spend more for a wheel chair lift? Now I see ADA laws and bigger forces at play.
Reply:Originally Posted by fdude64I hope I can lay dimes like that some day
GMT+8, 2025-12-30 14:22 , Processed in 0.102800 second(s), 18 queries .
