Corner mount security cam bracket.
发表于 2021-8-31 22:38:45 | 显示全部楼层 |阅读模式
Still struggling with bead width size variance   Better photos would just prove uglier welds.  I just need more bench time and more aluminum projects before I can say that I am truly "friends" with the Dynasty. I think I need to switch back to a smaller diameter filler rod for these smaller size parts too.In action...and yes it's not square by design, to compensate for camera design limitations.  The angle allows the CAM to view higher than a level horizon line and look up hill on 180 degrees of it's view area.Last edited by NoShopSkills; 02-04-2014 at 07:37 AM.
GMT+8, 2025-12-30 14:22 , Processed in 0.128170 second(s), 18 queries .
