Replacement for my SAM mig welder
发表于 2021-8-31 22:38:42 | 显示全部楼层 |阅读模式
There are plenty of MIG welders available but none that I've seen work like the SAM.  What I liked about my SAM was the ability to adjust on the fly from a knob on the gun.  Very handy when you are in a tight space and need to make a adjustment.  You could perfectly dial it in while you were running a bead.  Mine was damaged in a fire, the Co. no longer exists and I mis it dearly.
Reply:Do you have any info on this welder?  I just picked one up off Craigslist, but can not find any info on the web about it.Thanks for any help.I am tired of Ketchup, I want the Gravy...
Reply:Any help with this welder?  Can not find any info online.I am tired of Ketchup, I want the Gravy...
Reply:Get an old Lincoln SP250 our 255.   They have a switch on the handle you can use to adjust either Wire speed, Voltage or swap between 2 saved programs on the fly.   I had one for several years and is a great welder.   Seen them for under $1000 on Craigslist.  Very nice arc quality tooTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2025-12-30 14:23 , Processed in 0.099111 second(s), 18 queries .
