sa 200 main generator
发表于 2021-8-31 22:38:41 | 显示全部楼层 |阅读模式
Hello EveryoneHow do you determine if the main generator is good or not. Had engine rebuilt. Was welding before. Put in new main brushes. Checked armature and it is not going to ground. Trying to save a few bucks. Any help is appreciated. THANKS
Reply:Do you know how to or have you flashed the exciter?Often when a unit has been down for a period of time the exciter needs exciting with a shot of DC voltage to the exciter coils.  Done properly of course.Exciter Flashing Procedure.pdfMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks..no I do not know how to flashed the exciter  I fail to mention that I do have 110 voltage
GMT+8, 2025-12-30 14:21 , Processed in 0.097473 second(s), 18 queries .
