I have a question will a regulator for a propane cutting torch work with a 20lb BBQ tank?
Reply:Yes, that is exactly what I use, Smith propane regulator and bbq sized propane tank.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Check your fitting on the propane tank. New valves (from what I hear) are different from the old onesYou can use the old style if you stencil the tank "welding only".This might be a wealth of misinformation, but at least it's a heads up. Somebody might be able to nail it down better than I can"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Thank you for the help. |
