Roundtower YF-TM2 mill info
发表于 2021-8-31 22:38:36 | 显示全部楼层 |阅读模式
Hi all,Does anybody happen to know anything about a Roundtower YF-TM2 milling machine? I am unable to locate any info on it. I have the opportunity to get one tonight and would like to know if it is worth purchasing. Any help is greatly appreciated!Thanks!
Reply:I would be curious of cost. This is a knock of Bridgeport clone. What else do you need to know?http://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:I was able to get it for $800.  I was looking for a manual for it for setting it up and lubing it and specs.  If I cant locate anything for it maybe I can use a Bridgeport manual as it is a knock off.
Reply:A friend of mine has a "Round Tower" mill..And Yup it is a Bridgeport clone...Same Table..Same Quill..Same Back Gear set up...Same Handles...Same Door opening in the side for storage...800$ is a good deal..They take all the standard Bridgeport collets and stuff so tooling is cheap and available...Get it.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:ive been shopping craigslist for a year in atlanta and cant get anything under $2000.I get jelous when people post stuff like this =/
Reply:I got it!  Needs to be cleaned but overall not too bad of condition.  Ordered the phase converter yesterday so by Tuesday I should have it.
GMT+8, 2025-12-30 14:22 , Processed in 0.100146 second(s), 18 queries .
