7018 doing things wrong?
发表于 2021-8-31 22:38:32 | 显示全部楼层 |阅读模式
Sent from my SAMSUNG-SGH-I897 using Tapatalk 2 Attached ImagesLincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:Using 7018 3/32 .. DC+ 90 amp Sent from my SAMSUNG-SGH-I897 using Tapatalk 2Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:Sent from my SAMSUNG-SGH-I897 using Tapatalk 2 Attached ImagesLincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:What do you think your doing wrong?Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:Originally Posted by flux core joeWhat do you think your doing wrong?
Reply:Stop walking around the table while your welding.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeStop walking around the table while your welding.
Reply:Originally Posted by rockcrawler97Haha I wasn't talking around table I burned my foot and so my hand moved so the electrode went that way
Reply:Originally Posted by SquirmyPugDon't move when burning. Enjoy the pain. Also.. wear leather boots/shoes.
Reply:We have to work on your picture skills....These are picts of the same weld, or 3 different ones? The harsh contrast from the poor picts is possibly playing games if these are all the same..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:looks like you need to start filling joints! they are a little easier to stay strait on.start with a fillet, take two pieces and put them like an upside-down "T". weld the piss out of it! hows it look? undercut on top side? slow down and push rod "higher" in the joint and or use less motion. if your machine is set right, you should be able to just drag that rod through the joint and let your travel speed determine your weld size. if you go too slow, you will get a "cold roll" on the bottom where it is obvious that gravity pulled your puddle over itself without fusion.if you don't like your first pass, weld one on the bottom, then again across the top. how do you look now? can you draw a 45 deg. line from bottom to top plate and touch the edge of your welds? keep adding material until you feel like you are wasting your time then grab fresh plates and start again.
Reply:Originally Posted by DSWWe have to work on your picture skills....These are picts of the same weld, or 3 different ones? The harsh contrast from the poor picts is possibly playing games if these are all the same.
Reply:Originally Posted by 92dlxmanlooks like you need to start filling joints! they are a little easier to stay strait on.start with a fillet, take two pieces and put them like an upside-down "T". weld the piss out of it! hows it look? undercut on top side? slow down and push rod "higher" in the joint and or use less motion. if your machine is set right, you should be able to just drag that rod through the joint and let your travel speed determine your weld size. if you go too slow, you will get a "cold roll" on the bottom where it is obvious that gravity pulled your puddle over itself without fusion.if you don't like your first pass, weld one on the bottom, then again across the top. how do you look now? can you draw a 45 deg. line from bottom to top plate and touch the edge of your welds? keep adding material until you feel like you are wasting your time then grab fresh plates and start again.
Reply:Originally Posted by rockcrawler97Yuhp I have learned that many times I was just wearing regular shoes now I wear boots. My teacher told my always wear jeans when welding and one day I was mig welding and it gave me a nice ol sunburn on my leg.
Reply:Honestly your welds look perfect to me bead looks uniform,no undercut,nice ripples, etcLincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:Originally Posted by flux core joeHonestly your welds look perfect to me bead looks uniform,no undercut,nice ripples, etc
Reply:If you just want to run beads for fun, draw a straight line with a soap stone and follow it.Dan
Reply:Originally Posted by DanD78If you just want to run beads for fun, draw a straight line with a soap stone and follow it.Dan
Reply:too many pics and not enough welding, 5 pics of one little bead. put down the phone and pick up the whip
Reply:Originally Posted by TimmyTIGtoo many pics and not enough welding, 5 pics of one little bead. put down the phone and pick up the whip
Reply:Originally Posted by rockcrawler97using 7018 3/32 electrode on 1/4 metal DC+ running 90 amps
Reply:Isn't a flat stringer bead on the planet that really looks GOOD.  They all look high and ropey.  Your beads are fine!!!!!!!!  Edit: BEAD"Any day above ground is a good day"http://www.farmersamm.com/Anyhow, I gotta go out and put out some round bales.  Wearing my sorta ill fitting jeans, WITH NO BELT OR FLASHY BUCKLE, and a baseball capSo............carry on  the weld looks fine"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by ls1taFrom my experience, these look good. Like previously posted-try going in a straight line definitely. Have you done any v-grooves, or t-joints yet? Or are you still learning how to lay the bead down?Anywho, good luck!
Reply:Originally Posted by galencwiI agree  burn some more rod my friend
GMT+8, 2025-12-30 17:21 , Processed in 0.099430 second(s), 18 queries .
