Problem with my MIG settings, or my technique?
发表于 2021-8-31 22:38:31 | 显示全部楼层 |阅读模式
Hey folks,I have a common issue that I run into while welding small projects on the car or around the house, and would like to see if someone can explain why its happening. While welding, often the end of the wire will ball up and weld itself to my contact tip. So I break it loos and trim the wire and start again, and many times it balls up immediately again. Is it something in my settings or my technique I'm doing wrong?Thanks
Reply:What settings on the machine? Sounds like you need more wire feed.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Hmmm I cant remember exactly, I believe it was 16 gau and on my Lincoln Handy MIG I had the heat on High 2 and wire speed on 9, 10 being max speed.
Reply:What kind of wire and what kind of metalCheck for good groundThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:aluminized steel, grinded clean. Wire is .023 MIG wire, not sure on the brand, its what Arcet sold me.Maybe it was the ground, I had the workpiece in a vice and the ground clamp on the workpiece. Vice is bolted to the steel workbench. Does that sound problematic?
Reply:I would say more wire speed also.Does your contact tip extend beyond the end of the nozzle? I like mine to be slightly recessed to prevent the burnback from sticking to the tip.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-30 17:20 , Processed in 0.099672 second(s), 18 queries .
